Originally Posted By: DrRoughneck
Originally Posted By: Oldmoparguy1
multiple posts in what forums? In what time frame? In all my years, I have never heard of this. Do you have a link? I would very much like to follow up on this.
High wear because of idle:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3680353/fredfactory#Post3680353
Also:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/2039371/2
" At idle, valve spring loads cause high contact stresses near peak lift, and there is not enough centrifugal force to reduce it. So the cam lobe and lifter are forced together into boundary lubrication conditions, possibly leading to metal-to-metal contact. This is why oil used to have higher concentration of ZDDP."
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=37330
"I'm not sure when wear is the highest, but according what I have over and over heard, an engine shows generally more wear at idle (especially when cold) than when under load. Idling and revving an engine without putting load on it is especially bad for the camshaft bearings and cam lobes? "
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/2194028/Re:_Oil_Brand_doesn't_Matter_-
"Don't denigrate the test because it was done in a taxi fleet. One of the most severe tests that we do on valvetrains where I work is called the "Taxi Test". It's very simple; just run the engine at idle for 80% of the time, then do stop and go driving for 20% of the time. This is great for wiping out cams and lifters in slider-follower engines."
You're using one of my posts that's expressly about warm-up, another that is expressly about warmup...they are NOT about your topic, or statement to that effect.
