Originally Posted By: GaleHawkins
Originally Posted By: earlyre
Freeze would be my only concern... 2 January's ago, when I bought my car, we were in the middle of " the polar vortex", and temps here stayed subzero for nearly a month(very rare here), with strong winds. It's reservoir was both full, and frozen solid with the cheap diluted [censored] they dispense in bulk. It was nearly a month before it was warm enough, long enough to thaw enough I could siphon the [censored] out.
earlyre just today I siphoned the diluted blue washer fluid out of the 2006 Ford Five Hundred (on the same Volvo S80 chassis as your Sable I read). I put in some Prestone washer fluid good to -27F degrees and is to help with snow/ice removal. It was not fun driving in slush with frozen nozzles. I covered both and pumped the new yellow fluid until it turned from blue to yellow.
yeah, it was the sable, and when i say it was frozen solid, i mean solid. as a rock. and instead of just running the pump until dry, i stuck some aquarium airline tubing as far down into the reservoir as i could, sucked on the other end, until flowing, and let it drain into a bucket.
that was what i always hated about my pre-bitog days, if i didn't have my washer bottle full to the top, the quickie lube would use their bulk junk, which would promptly freeze in the lines...
used to always use the orange rain-x, now, i stick to the Purple stuff at Meijer(something Maxxx).it's cheaper than the Rain-x, protects down to -40, rain/bug repellent, and it's purple.
I like purple.
