Hi, I am the original owner of a 2001 Honda S2000. Car is in showroom condition with 40,000kms... only driven in hot dry summer days with the roof down. Never seen rain or snow.
In the past 15 years the car has only seen the following for maintenance:
Yearly Oil/Filter Changes with either M1, GC, PP, VMax Life... 10W30/5W30/0W30..note: the engine consumes zero oil even with frequent thrashings to 9000rpms
Yearly Cold Air Intake Filter Clean
Coolant, Brake, Transmission, Diff Fluid flush every 3 years
Spark Plugs were changed once during a TSB in 2004
Tires... its on its 5th set
Battery replaced 3 times...its always plugged into a tender
Since it is 15 years, should i be looking at replacing other things like rubber rad hoses, heater hoses, seals? Everything still looks like new on the car..i cant find anything rotting, cracked or split...
Fuel Filter is not serviceable as its in the tank.
I do need to change the cabin filter... it is original... when do i ever use the HVAC anyways??
Wipers are original...they're in mint condition.
Am i Missing anything ??
Any thoughts would be appreciated
