Originally Posted By: Bill_G
Originally Posted By: yeti
Originally Posted By: artbuc
Originally Posted By: engineer20
how's red grease
This question reveals your keen engineering insight, once again proving your engineering prowess. SAE uses the same grease color code that plumbers use to avoid confusion. Red grease is for hot systems like your exhaust. Carefully smear the entire system from manifold to the end of the tailpipe. Make it 20mm thick in the winter and 5mm thick in the summer. Use blue grease on your cold systems, eg your A/C compressor and expansion valve. Automotive repair is easy if you follow these simple rules: red on hot, blue on cold; lefty loosey, righty tighty; i before e except after c and what goes up must come down.
good post.
but,you forgot one detail.the odd number years call for METRIC grease on Japanese models, in February.are you sure that 20mm. is enough ?
bill g -- why would you want the thread deleted ? a large number of posters are having fun, and are being entertained by e20.there's always one who wants to ruin things for others. if you object to his threads/posts,or have no sense of humor, put him on ignore, or don't read the thread.that's too easy. ruin it for others.that's the way to go.go outside, and holler -- git off my lawn!
Oh I've got a sense of humor and you make some good points but E20 seems to feed off people submitting rational responses to his irrational never ending posts and questions. If the purpose of this thread is to, as you point out, entertain a large number of posters, maybe it should be in a different section. I do have to admit, I keep reading to see what's gonna be said next.
You've got me pondering that metric grease stuff for our cars.
you bring up a couple of good points, as well.
I don't think that his original intent was to entertain, but, you 'gotta admit, a lot are having fun with his posts.maybe, at this point, his threads should be directed to the humor section.calling his posts irrational is being kind.
at the end of the day, who cares, as this is the internet.
re: the grease -- metric grease MUST be used on Japanese cars' exhaust systems, and the muffler bearings. in February.and, only on a Tuesday.
have a good night.
