Originally Posted By: 2015_PSD
Originally Posted By: JStep
Like Dustyroads said, it does smell quite a bit. Took me a little longer to get rid of the smell than he did. (smaller engine, less miles).
You guys have piqued my curiosity--is it the smell of the oil in the bottle that you are referring to or the smell of the exhaust after adding the oil? If neither, where does the smell originate? Thanks for posting the UOA; nice to see Kendall being used.
It will make you cringe but, try to imagine popping the hood of your truck (when hot) and pouring a gallon of oil all over the engine. You would get a hot, burning oil odor. That is what it's like, except it is sort of an oil/chemical mixture. I personally think it leans much heavier towards a burning chemical odor and I wonder if it's the titatanium additive.
I didn't smell anything as I poured it in but I was distracted with conversation at each service. It's coming from the crankcase, not the exhaust. I truly freaked out and stopped on the side of the interstate because I thought a filter or oil line had come loose and was plastering the engine with oil. I have almost ten gallons in the sump so that made for a strong odor as it heated.
I hate to admit it but I freaked out the second time (using the oil) and the third time it still got my attention.
