Quick question, I have to send out 755 post cards or regular letters on the 22nd of each month except for December and i need to print out addresses on peel and stick labels what is the best program to use or the best way to do this?
Take them to a mailing service. I believe FedEx and UPS Stores do this, and there are probably some small local companies you could find that do it as well.
Avery (the label people) have sheets of labels (or various sizes) that you can feed through a printer, and supply the formatting/software to make it fairly easy.
I'd suggest finding a way to print the addresses directly onto the postcards or envelopes. No way would I want to peel and stick 755 avery labels every month, much less pay for 755 avery labels every month.
Find a printer that will print on the desired size/thickness of paper, then figure out the mail merge funcion in Microsoft Word.
Figuring out the fastest/easiest way to do this NOW will save TONS of time and money later on.
