Originally Posted By: cutter
After a comprehensive search for a hot sauce that has the same flavor profile of a louisiana cayenne/vinegar sauce such as Franks, Texas Pete, Louisiana, Crystal etc, but at a much higher heat level (50k scoville or higher). I finally found it in Tropical Pepper Co Ghost Pepper.
Namely I've been looking for something to make an ultra hot buffalo wing sauce that is true to the buffalo wing sauce flavor. Prior to that, I've tried straight capsaicin extract, but that has a very distinct taste to it and shows up in the sauce. Other ultra hots vary wildly in flavoring.
http://www.amazon.com/Tropical-Pepper-Company-Ghost-Jolokia/dp/B0070XYM1I
Check yourself if you get too crazy with the ultra-hots. I know ghost peppers can range in SHU depending on where they're grown...but 500K SHU is still mighty hot. Hot enough to create esophageal issues for some folks...and it doesn't take much. A friend of mind thought he had the iron esophagus and stomach lining until he was diagnosed with esophageal erosion issues related to his consumption of hot peppers and ultra-hot sauce. Don't want to be the wet blanket but it's something to be aware of....
