Drill a half inch hole in your existing plastic cans in a spot that suits you then put a tire valve stem in the hole with the valve core removed . works perfect . About every two years you will need to replace the valve stem because the fuel seems to make them get soft ..most tire shops will sell you stems way cheaper than you can buy them at the parts store or Walmart .
