engineer20
Thread starter
picture of the oil pan I installed, and got from the junkyard, from the scion tc, 4.2 quts, a new oil pan is often made by spectra, is nice sand shiny but is 4.5 qts, but the oem is 4 quts. why the difference and i heard more oil= better since more cooloing, did they change it in the aftermarket to 4.5 since the figured 4 qts was too little for this engine? thats what the guy at s and g who had a dorman in stock for 100 ish (too much) whereas the spectras are like 85.99, said.
i installed this, will it be bad, or should i redo the job with a new oil pan?
again, not taken with the iphone, dang, the iphone gives out stalkerish info, but my cheap samsung doesn't provide those details, good to know
but notice the rust, i emailed samir at blackstone labs and showed him the picture, and he said it was fine. opinions/ i installed this.
also, about angle grinders, which arbor size is better 5/8 or 7/8? i bouth a 7/8 wheel but 5/8 angle grinmder, should i return it and buy a 7/8 one from h freight with the coupon this super bowl weekend? Thanks.
