OEM tires are often not quite the same as the same model tire purchased after the fact, so that might explain part of it. The other question comes to: have your driving habits or usage of the truck (towing, etc.) changed?
If they're worn evenly, it's probably not an issue with the truck, but either the tires not being identical to the first set or a difference in how they're being used that's causing faster wear.
