In keeping with my photo-logging for your entertainment, I thought I'd make another thread on another engine swap job. (other is a beat to &^$* '93 F250). Vehicle is a very clean and well maintained, one owner rig with 109k miles. It developed a knock that went away as it warmed up a bit. Owner called me up and started quizzing me on my opinion. He had worked a few mech jobs before and does somewhat know his stuff. Thought it could be a scored piston. Called back later to say it's getting noticeably worse- I told him that pretty much ruled out piston slap as it pretty much gradually gets worse.
I went and picked it up, then let it sit outside to get cold again. Once cold, I plugged my scan tool in, started it up and proceeded to shut injectors off to isolate which cylinder it was (you could hear it was a piston noise). When I got to #3, it quieted down noticeably. Pulled #3 coil and plug and stuck the bore scope in there to find that the bore was scored at the thrust axis. If the bore is scored, I can imagine what the piston looks like.
So the owner thought it over and decided to go with a re-man. Once I get time and room, I'll bring it in and start snapping some photos of the swap. If I think about it, I'll even get a quick video of the engine knocking... Sorry guys, no pics yet- just wanted to get a thread going now while I've got some time so it wouldn't take quite so long when I get pics.
