This completes the cut & post on a Champ Labs PH820 oil filter.
This photo shows the 6 inlet holes are completely within the center tube diameter. It also proves the leaf spring is not part of the bypass function. Only the shape and material properties of the nitrile rubber combo valve.
This shows the even pleat spacing, the benign dye or ink spots on the outside, the splice with glue and the fiber end caps.
Media width 2 3/16"
Media length 78"
Media area 170.6 sq in.
52 pleats
Pleat depth 0.75"
This shows the cage.
Core ID 1.5"
Core OD 1.75"
Core length 2 1/16"
Core description - 5 circular rings 1/16" thick on 1/2" centers; 4 vertical ribs spaced 90 degrees apart.
My biggest concern at this point is the window is too wide. Even so, I likely will use these up. Since the dye or ink spot on the inside of the filter is not of concern. These trump the Motorcraft FL820S as follows: no rust and near perfect pleat spacing. It is obvious Champion Labs is using a corrosion inhibitor. I will have to run them to see if the pleats tend to collapse or not.
It did take some effort to pull the end caps from the filter media. I noticed that some of the pleats were glued together at the core on the thread end cap and the dome end end cap. That would tend to block the flow a little at those 2 points.
This is a quote from Champion Laboratories web site: "Champ filters not only meet, but normally exceed original equipment requirements for fit, function and total replacement value." There is wording to the effect the use of these filters will not change the vehicle manufacturer's warranty on the box.
I think the filter is good through the manufacturer's recommended OCI.
The STP S2 and the AC Delco PF1250 have 8 vertical ribs cutting the window in half. I think this is a step in the right direction for an eCore design like this.
