The two Fords in my signature both take the Fram Ultra XG-2. I changed both filters last weekend and had a bugger of a time getting them off. I did get them off but it took way longer than it should have. They are stuck up in the engine whereby the regular oil filter wrench I use doesn't have enough room. I need a cap style that goes over the end.....something I can put on the end of a ratchet and extension, gently turn it and viola, its loose. I bought one cap style but it is really shallow, didn't grip well and didn't really fit over the black grip stuff on the end of the filter. Basically it was worthless and got tossed in a box in my garage. What do you guys use to get a filter that size off?
Fram lists the diameter of the filter as 3.66".
TIA for the information
