You don't need or want to clean an engine that has no problems. By trying to clean an engine that has no runability problems you risk breaking free carbon and sludge and plugging an oil passage or oil sump screen. Goodby engine. Don't create a problem where none exists. Engine cleans using home brews are to be avoided except under extreme circumstances when you have a problem and nothing to loose. In this case what would possible be gained by stirring up crud in an engine that's running fine?? What?? And yes, do read the manual. The arrogance that making a home brew is smarter than following the maintenance directions is absurd.
I can't believe the pushback this is getting. Don't do flushes and cleans as part of maintenance when there is no problem. You literally could cause your engine to fail.
