Around 1989 I changed to oil on my 84 Tempo diesel 5 speed stick. It was in the winter and had the garage door closed and the front of the car on ramps. After finishing the OC and the hood still up. I was inspecting everything and leaned on the front of the car. To my horror the car started rolling off the rams. I left the trans in neutral. Down the Tempo flew and right through the steel garage door, pushing it several feet out side.
Well not much harm came to the car, I spent the next 2-3 hours taking hinges and rollers off straightening and welling. Sure learned a lesson from that.
