2001 Toyota Sequoia. It has the motorized antenna mast. I am posting here to get some assistance on lubricating this mast. I used silicone spray and apparently it froze because the antenna won't go up but about 4-5" when the weather is below freezing. it works just fine any other time so I know it's not the motor. So, I need to clean off all the grease and silicone and then lubricate it with the correct lubricant. My two questions are;
1) What is best to clean this old grease and silicone off?
2) What is best to lubricate the mast with for all temp operation?
Thank you in advance for any assistance you are able to provide.
