Originally Posted By: Oey12
I have a 2012 Tacoma that I wil be replacing the tires on it soon. The current size is 265/65r17 but I want to jump up to 265/70r17 michelin ltx defenders. I know most guys upsize to all terrains but I have no need for them and in the past I surprised how well they do for a highway on basic trails except in mud. Question is am I going to lose a lot of mpg's going up in size. They are extremely light tire (39.6 pounds). And what affects gas mileage more size, weight, or tread pattern?
First, the biggest factor in tires vs fuel economy is the tread compound. No doubt, you are going to loose big time in that department if we only consider the change in make and model.
But if we consider the difference in overall tire diameter it might be a wash.
- AND -
It might be that the electronics in your truck will not like the difference in tire diameter. I've heard of such things and suggest you thoroughly research that BEFORE you commit this transaction to cash.
Also, you should be aware that new tires will get worse fuel economy compared to worn tires, all other things being equal.
