Originally Posted By: 901Memphis
Originally Posted By: Rolla07
Swap the 9006 for a 9011. More light lumenhttp://www.amazon.com/Wagner-Lighting-9012LL-Headlight-Bulb/dp/B0080DLA9E/ref=pd_sim_263_2?ie=UTF8&dpID=411TX4aIy0L&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=15VY5BXDTGEX9D7Q5BAA than 9006bulb. Just need to trim the tab with nail clippers.
9011 is not the correct upgrade for 9006. 9011 is a high beam bulb. It's possible to swap a genuine 9012 in place of a 9006 but only if that's in genuine non clouded oem housings, not aftermarket. Adding more lumens to a poor aftermarket housing will just create more glare for everyone since they don't have the correct quality optics to utilize it.
Oops my bad..was sure was 9011 but you're right its 9012. I am using wagner 9012's..about 18$ each on amazon. I havent upgraded my brights..i feel they are good enough.
