I have a friend with a '07 Grand Cherokee that she received from her step-father after he upgraded vehicles. It has aftermarket projector housings on it, so I thought it had HIDs.
She was complaining to me last night about the headlights being near unusable to where she has to use the fog lights to get any light on some back roads. She was talking about getting the factory headlight housings and having me put those back on.
I couldn't understand why the projector HIDs would be so terrible. I figured, oh they are pointed way down or something and just not throwing light very far.
We went and looked at it. I put my hand in front of the light. Sharp straight cutoff until the middle where there was a bright spot. Most of the light was focused there, like a flash light.
Pop the hood, and her step-dad has took these (presumably) HID housings and put a 9006 in it. To adapt it from the 9007 or what ever factory bulb, he has spliced in the 9006 harness with wire nuts and electrical tape.
So, I told her Ill fix it next time shes over on the east side of the state. Probably going to reinstall the factory housings and bulbs.
But, I was also going to look into converting it proper or putting LEDs in it (probably easiest after I fix the harness) to make good use of the housings.
I have soldering gun and that good heat shrink that squirts glue out the end to seal, so that harness won't be any issue.
I don't know what the deal is with the 9006 bulbs in these. I couldn't tell if the bulbs were modified or, it just happened to fit. What do you guys think?
