Hi all,
Need to pick some brains.
Issue:
2010 Taurus, replacing rear brake pads & rotors.
I can get the caliper piston to screw in and out just fine. But when I put everything together and apply the brakes the piston won't retract and you can barely turn the rotors by hand, which clearly is not ideal for brake pad life and MPG.
Any ideas why it wouldn't retract? I'm thinking maybe something with the emergency brake?
Issue:
