The numbers matching engine in my bandit has cracks at the floor of the block. It has a slow drip when cold. Various stop leaks work for a while then it starts up again.
My plan is to punch out the freeze plugs wait for the block to get dry then pump in something to fill the bottom 1 inch of the water jacket. To the bottom of the freeze plug hole. This is done all the time on street/strip engines with no overheating consequences. It strengthens the block keeping the cylinders from moving around.
Anyone done this? There are a few different products out there some being concrete based and others epoxy based. Then I've seen big tubes of jb weld at az for under 20 bucks being the cheapest option.
