2006 Civic 1.8L Auto, 240k on trans/chassis. 150k on motor (cracked engine block issue, Honda defect)
So I have this bearing sound only between 3.5k and 4k RPMS and doesn't matter what gear I'm in. So at first I figured is was the idler pulley since it wasn't that tight when spinning it by hand. That obviously did not fix the issue. I've tried running the car with no serpentine belt to see if it was one of the other pulleys but I still get the same sound. There has to be load on car to make the sound.
It will NOT make the sound while revving the motor in neutral (standing still or rolling down the road) or if the car is on jack stands and in gear. I know not that is not the safest thing to do but I can't figure this out.
Any idea on what may be the issue or another way to diagnose it without a dyno? The sound has been going on for about 20k. I drive 50k a year in the car for work.
