engineer20
Thread starter
Here are some more pictures. I cwent back to the caliper place with the spring, which you see, but he said he can't attach it without the bracket which is still on the ebrake. This was taken at night, so it might not be clear, but I had an led flashlight to light up the area.
How do you take that bracket off so I can go back to the caliper palce for him to completely assemble it so that I can finally put the caliper on the car? And on the side is an AAP "wearever" but really oem caliper, as it's a bosch with a fordmotorcompany seal on it, so it's an original core, which is good. I gbought it as backup and also to further understand how the caliper is assembled and plan to return it if this remanned caliper works, it's from a place called Quality Caliper, in I believe, Ferndale, MI.
