The steering shaft on my truck has a ton of play in it and needs to be replaced, but I'm having a hard time getting it to come off the shaft that comes from the steering wheel. I have used pb blaster, heat, an air chisel and pryed/beat on it every way I can imagine. Any tips to spread the part and get it removed? Obviously I've had the bolt out while I've been working on it.
