Originally Posted By: mlatour
Using auto racing terms,
Most vehicle manufacturers intentionaly make the handling traits to feel 'tight' (front end push) rather than 'loose' (rear end slide) as a safety factor.
If the vehicle is pushed beyond it's handling limits,
an unexperienced driver will usualy let off the gas sooner if the front end starts pushing and regain traction easier. (no counter steer required)
Most performance enthusiasts prefer a slightly 'loose' handling trait,
being able to handle a vehicle that hangs the back end out a bit going around / exiting corners under power.
On an unloaded pick-up truck, a stiff rear sway bar makes the back end 'loose' (less body roll) and more prone to slide.
Likely true, but I fail to see how this applies to trucks with 18" wheels versus those with 20" and how theoretically it could cause a problem with the axle or tires.
