I've seen this brought up here and there but I'd like to bring up a new discussion on it. evolutionm.net swears by this oil as the only oil to use in the t-case and rear differential. I've actually had a t-case go bad (not uncommon at all, especially at higher power levels) on my old evo while using amsoil severe gear 75w90. I don't attribute it to the failure, just a note, however:
Is there something special about this fluid? I've never been able to find any specs on it, other than it is SAE90 & GL5. However, it seems all SAE90 fluids run in the 13-24 range at 100c, and 600-700 at 40c.
Obviously, there is more to it than just viscosities, but here are a few examples of 75w90:
amsoil severe gear 75w90: 16.8 @ 100c, 109 @ 40c
motul gear 300 LS 75w90: 16.4 @ 100c, 109.6 @ 40c
redline 75w90: 16.1 @ 100c, 112 @ 40c
75w110:
amsoil severe gear 75w110:
redline 75w110: 20.9 @ 100c, 131 @ 40c
motul 90PA (not sure if this is sae90, doesn't seem to match specs): 14.5 @ 100c, 140 @ 40c, rated for GL4 as well as GL5.
Is there any reason why a 75w90 or 75w110 wouldn't work in place of the Diaqueen? Some special additive that isn't disclosed? The hearsay on evom is there have been a lot of failures on non-diaqueen fluids, but I'm not sure why that would be the case.
75w110:
