Originally Posted By: Doublehaul
I would NOT be comfortable with his recommendations fwiw...but it looks like your mind is made up.
That being said my father has a 3800 series II that requires 50wt oil to keep oil pressure. The engine suffered from a hydro-lock after the intake failed early in its life (45k) doing damage to the lower end. With anything below 50wt oil, the low pressure light flashes at operating temp. The low pressure has been verified by a gauge as well. That being said...all is well pressure wise running 20w50.
We run castrol or supertech 20w50 out to 5000m oci and UOA on both have shown great wear numbers and TBN retention. I can personally vouch for either of these oils.
I should also add that while his 3800 runs great, modern engines use oil for more than just lubrication. They use it for hydraulic actuators and some cases piston cooling. I would NOT recommend this grade of oil if your engine uses this technology
That being said I live in Northern Michigan and its very cold here more than half the year. The starter has a very hard time turning the engine over with that oil in there and as a result we have to replace his starter every couple of years. The car now has a tick over 200,000 miles on it though and is still running strong.
It's not that my mind is made up. The engine has been together and running for a year, lol. I should have mentioned that in my first post. I've been using the valvoline conventional 20w50 since new. It runs good too, LS engines with cnc'd cylinder heads and a big cam is a powerful combo. But I digress.
I was just wandering if there was a better brand of oil in the 20w50 viscosity. I've been reading about brad penn oil, and also valvoline vr1
