So I went and printed of all the info then processed to read the whole thing sitting on the sofa.
I did learn a lot about oil, for sure. Bob never really comes out and says that one oil is necessarily better then the next but from my reading he seems to point out that in colder climates or even just in general that a Synthetic oil is much better.
"Since the synthetic oil thickens less on shutdown your startup will be easier and so will the stress on your engine. This is perhaps the best thing the synthetic class has over the mineral based oils." (Chapter 4)
"It would be more correct to think that oil thickens when it cools to room temperature and THIS is the problem. In fact this is the problem. It is said that 90 percent of engine wear occurs at startup. If we are interested in engine longevity then we should concentrate our attention at reducing engine wear at startup. (Chapter 1)
Would it then make sense to run synthetic in the winter months and then in the spring change out to a thinner mineral base? I would be inclined to run a high mileage oil as my Ranger 3.0L is up to ~180,000km and the wife G5 is ~140,000km.
Any any thoughts on switch back and forth like this???
