Originally Posted By: Lubener
I doubt there is a milliamp of current flow, more like microamps. You can have some situations, have a voltage potential on the braid due to grounding issues between the two ends, it's called a ground loop it happens once in a while and is not good.
I would rather start with a good quad shield RG6 anyday versus an RG59 and an amp. The amp is going to amplify any noise present in the line brought on by using cheap "video" cable. Why not do it right from the begining.
I beg to differ. The amp will amplify the best quality signal available at the antenna head which will give you a better S/N ratio.
The increased signal strength of the amp will also give a person the option to split it for 2 TVs if you wish.
IMHO using quad shield RG6 for an attic antenna is like washing my feet with Perrier .... very expensive and unnecessary.
