Originally Posted By: Hokiefyd
You should be able to hear it rattle, though I do concede that it's pretty faint. This is the same PCV valve design used on all Honda J-series V-6 engines. Both of mine rattle a bit when you shake them, but it's faint. They tend to not get all that fouled up. You can spray it out with parts cleaner, but they're not very expensive to begin with, so it's probably worth it to just replace it.
Old PCV valve was fine. I installed the new one because I had it, but the rattle on the new one was the same as the old one. Both muted compared to conventional valves because they are all plastic inside except for the spring. Also, the valve is not 100% unidirectional. The design allows for a minimum reverse flow which threw me off. Conventional valves only flow one way. Oh well, it was not a very expensive mistake and I learned a lot. There is a wide range on pricing so shop around. I found the best deal at Bernardi Acura on-line. Best to add valve to an order with other stuff to save on shipping cost.
