Originally Posted By: 901Memphis
Do you know about friction ratings? Make sure if you buy something in store it's no less than FF which is the standard in pads these days. You may be able to find a GG pad like Wagner thermo quiet. Anything DD,EE,EF,FE she be avoided. If you can't see a friction rating anywhere on the pad itself or the backing plate run fast from that part.
I am loving my Wearever Platinum ceramics from advance they are FF and lower dusting. Most of the top pads at parts store are FF or better.
http://www.bimmerfest.com/forums/attachment.php?attachmentid=294889&stc=1&d=1317139611
A lot of semi-metallic pads are EE or FE rated. I just received a box of Textar front pads for a 330ci and they are FE rated, and I'm sure the pads are going to perform fantastic (since that's what's currently on there).
The friction rating only tells part of the story.
