Originally Posted By: supton
On my Camry I've taken to lifting on a large metal bracket, there is a trailing arm that goes to it. It's less than six inches from the pinch weld though. So now I use a small bottle jack to lift, as there wasn't enough space to run a floor jack & place a jack stand.
I don't have a floor jack long enough to lift from the center of a vehicle, so central jacking point is out for me also.
I lift *the whole side* of my camry by jacking on the unibody rail, the one a foot inboard. I put the jack about a foot rearward of the firewall. This lets me put a jackstand in the proper place, between wheel well and the jack in front.
If you keep at it, the rear will lift too. Cars are stiff enough now you can get away with it.
