The Focus just turned 150K(miles) and thought I would give a run down on this car. Parts replaced.
1) Engine coolant thermostat
2) Top motor mount
3) Two alternators
4) Heater fan control switch
5) Brakes on all four wheels
6) Both front headlight bulbs
7) I change the so called life time air filter box and replaced it with a Doorman unit that takes a normal paper filter
8) Battery
9) Sway bar link ends
That's about it. We use this car as our grocery getter and gets a lot of local miles. The engine still runs great and shows no sign of engine wear. Engine is very clean through the oil fill hole, and uses no oil in my normal 10K OCI. Also the trans shifts fine with my 30K fluid change it gets.
2) Top motor mount
3) Two alternators
8) Battery
