Originally Posted By: Avery4
Does that mean that it is at least as good as the part the car came with?
Not really, it's a fairly nebulous statement if you ask me. Unless they perform the same testing on said part as the OEMs do, and it demonstrates similar performance/reliability/etc (or whatever criteria they measure), then it's impossible to prove or disprove.
That being said, many of the OEM suppliers sell the exact same part without the OEM branding. In that case, it *should* be identical assuming they aren't changing anything else in it. An easy example is a brake rotor. If you buy replacement oil filters for my car at the dealer, it has the BMW logo and part number on it. But if you buy the same oil filter from Mahle (who makes the OEM part), it simply has Mahle's logo and part number on it instead. Exact same filter with the same construction, pleats, endcap, etc....for about 25% less.
