Wipers Do Not Work When Cold
Colorado
The wipers on my wife's 2002 Odyssey do not work when it is very cold out. Or they work sluggishly. No, the blades aren't frozen to the glass
Does this indicate a failing motor? Switch?
Is that a DIY item?
had the same problem, maybe the relay gets stuck. I changed the relay when I had this problem and it worked. So try maybe swapping a relay and hopefully you get away cheap
I had that problem on my F150. To make matters worse, intermittent would stop in mid wipe. I would replace the relay and it would be fine for a few months before it was acting up again. I would get relays at the dealer, the auto parts store. It didn't make a difference. Then ten years ago, I popped the cover of the wiper relay with a utility knife blade put a wee bit of light oil on the relay contacts with a small syringe and re assembled. I have never had problems since. I know someone with a Kia Sedona who had the same issue. I gave the relay the same treatment and he hasn't had problems since as well. You are most likely to have problems with intermittent wipers because the computer sends a small pulse of voltage to the relay. If the relay contacts didn't complete the circuit in the span of the pulse, intermittent wipers will not work properly. The relays on both vehicles look like they could interchange with one another.
Thanks, I'll look into replacing the relay. Sounds like a good candidate, based on what you guys have said.
