Lab # H26771
Code 20/32
Report Date 1 15 2016
Miles on oci 3859mi
Miles on motor 194209
Aluminum 4 Avg 3
Chromium 0 0
Iron 8 9
Copper 1 1
Lead 0 0
Tin 0 0
Molybdenum 226 292
Nickel 0 0
Manganese 0 0
Silver 0 0
Titanium 2 1
Potassium 0 0
Boron 213 355
Silicon 5 6
Sodium 4 7
Calcium 2063 2364
Magnesium 4 10
Phosphorus 644 696
Zinc 734 847
Barium 0 0
Sus Viscosity at 210F 59.5
Cst at 100F 10.07
Flash 400F
Fuel Antifreeze 0
Water 0
Insoluble 0.3
Blackstone Report of 2 Pennzoil Ultra Platinum 5w30, 1 qt 5w20 Pennzoil Ultra Platinum and 100 ml of LM Motor Oil Saver, 100 ml Ceratec and top off to fill line with Pennzoil Ultra Platinum 0w40.
Filter is Injen dry flow nano filtre with dry charger
Oil Filter was Napa Silver
Throttle cleaned prior with CRC IVD cleaner and fuel is E 0 87 Caseys with Gumout All in One.
Current fill is Pennzoil Ultra Platinum 5w30 with full bottle LM Motor Oil Saver and 30ml of Ceratec.
Notes._Wear metals are low here.Viscosity is in the 5w30 range. Low insoluble and silicon just like last time, shows excellent oil and air filtration. At this rate, another 200,000 miles should be no problem.
--Alex
Code 20/32
Miles on oci 3859mi
Aluminum 4 Avg 3
Chromium 0 0
Iron 8 9
Copper 1 1
Lead 0 0
Tin 0 0
Molybdenum 226 292
Nickel 0 0
Manganese 0 0
Silver 0 0
Titanium 2 1
Potassium 0 0
Boron 213 355
Silicon 5 6
Sodium 4 7
Calcium 2063 2364
Magnesium 4 10
Phosphorus 644 696
Zinc 734 847
Barium 0 0
Cst at 100F 10.07
Flash 400F
Fuel Antifreeze 0
Water 0
Insoluble 0.3
--Alex
