In installing O-rings and seals, you usually want to lube the seal. For food and potable water equipment, this is normally done with a food-grade silicone lubricant.
Is the job of this lubricant pretty much done within a short time after reassembly, or is there some lingering job the lube performs. Is there a practical advantage in higher or lower viscosity lube for this job, or is it just whatever is convenient to the installation process?
If this O-ring is making a seal that slides (such as a water softener valve piston) vs one that stays between two pieces that do not move, how does that affect choices?
