I'm starting to get very annoyed with how T6 is performing in my engine. I did change the turbo, however, I changed it out for a used unit with 4000 miles on it, not a new one. There is still bearing wear showing up (albeit small) in the form of lead. It definitely seems usage related to me. Lead has been high ever since I started tuning the car for a methanol mix. The 15 ppm sample was taken after a track event where the car was driven very hard.
At my next oil change, I will be switching to a full synthetic 5W-30 gasoline engine oil of some variety.
I'm not sure whether these levels are high enough to worry about the condition of my bearings at all. Hopefully some of you all can chip in on that.
In case anyone is wondering why my fuel dilution has all of a sudden plummeted, please be aware that my usage has changed: I am now commuting ~55 miles one direction to work instead of 1.5 and this is the reason it is no longer an issue.
