I've never seen this before on any of my cars. Either a belt cracks or breaks, but I don't ever recall one being shaved down such that little rubber flecks are being strewn over a fairly wide area.
I think it's coming from the belt as it rides under the belt idler pulley on my 4.6L. The most shavings are directly below and above that pulley. Those bits also ride the belt and end up elsewhere such as the face of the alternator or on the inner fender ledge...or at any point along the belt travel path. My best guess is that it's the edge(s) of the belt that must be rubbing somewhere or getting overheated near the engine somewhere. I don't see any direct contact from above though. Both edges of the belt do look a bit rough and crusty. A 1/4" pile of shavings accumulated under the BI Pulley. The BI Pulley has some shiny worn spots on the surfaces that I don't recall seeing before. After tonight's 10 mile ride (in 32 deg F weather) I checked the belt and it was cool to the touch.
I don't recall seeing this problem back in August so it's probably fairly new. My local shop replaced the radiator at that time, though I don't see where they would have done anything to the belt/pulleys. Will continue to monitor it every couple days. They're supposed to be replaced at 100K miles. At 68K mine is not cracked or brittle.
Anyone seen a belt shedding rubber like this before?
