does anyone have any info on these units? its a thermoking twin cylinder compressor, i want to use this as an air compressor for shop air. i have a 40 gallon tank to mount it on. this has a pickup tube and oil pump so i presume oil does not need oil to circulate through the compressor side to provide lubrication. parts for this a cheap enough so i'd like to keep it and fix it up even if i don't find a use for it.
this is about the most info i can find on it, tried emailing but didn't get a response.
thermoking.com
also- what oil should i use?
thermoking.com
