Originally Posted By: snakyjake
Is there a compiled list of oil filter that are compared by filtration, capacity, oil flow?
Thanks in advance. Jake.
In terms of the three criteria, you're going to be hard pressed to find full detailed data for all major brands.
Some brands will discuss general statement such as efficiency to ISO protocol, not all will. Heck, there exists silly debate here time and time again about the Fram statement (is it equal to or greater than .....
When it comes to capacity, fewer statements exist. Some premium filter will mention their capacity, but typically not the "normal" filters.
When it comes to flow, other brands may make a statement, but not all. Wix will state flow and some other criteria, but they took a "whitewash" approach to the eff a few years back ...
I will say this. Nearly all data I've ever seens shows that flow is NEVER an issue. Just about any filter will flow WAY more than the pump is going to push. A swag on the value would be perhaps 2:1 in terms of flow potential versus pumped volume. IOW - the filter will flow (generally) twice as much as the pump will move. So, in effect, it's moot. What little difference that would exist in flow delta between brands is completely inconsequential.
Same goes for capacity, relative to the application. Over-extending an OCI way past the capacity of a filter will always be a bad idea, but my personal garage testing has shown that even "normal" filters (Puro Classics, MCs) can easily go 2x or 3x the "normal" OCI on a healthy engine. (Nasty sludgers and neglected equipment are excluded). So, again, there is way more capacity in a typical filter than your engine would ever consume. What differences may exist between brands (tier to teir) is simply moot. What loading a FU can hold versus a M1 or other syn media filter is simply silly; they will all hold WAY more than you'll put in there. Same even goes for normal stuff like the OCOD and a Classic and such; they have a really good amount of holding capacity that is likely to never be usurped by your normal OCI. I ran 10k miles on a classic and 15k miles on a MC; neither showed any signs of durress upon teardown.
What I am trying to show is that, regardless of what comparison/contrast you can find, all the major brands are made well enough that they are well more than qualified to work in their intended application. Certainly we have seen various failures of filter media occasionally, from more than one brand. But overall I think the market is well served by the genearal offerings out there. And they are all engineered to serve the intended OCI, and probably well past that "just in case" ....
