Originally Posted By: marco246
I, too, have an Alfa 4C which is going to need an oil change in a couple of months. The owner's manual (2015 FCA US LLC, third edition) requires an SAE 5W-40 full-synthetic engine oil that is API certified and meets the requirements of Chrysler Material Standard MS-12991. There is nothing stated about industry specification ACEA C3.
I have bought a case of Pennzoil Platinum Euro PP 5W-40 full synthetic which ought to do the job. It exceeds the Chrysler spec noted above as well as API SN/CF, ACEA A3/B3 and A3/B4 as well as Ferrari and Maserati specs and many others.
I apologize for coming in late on this issue, but I don't see the need to look around for an ACEA C3 oil at all.
Best Holiday Wishes to All!
I have been away for a bit. Odd I have not come across you as there are not many of us around. I don't recall seeing you on the 4C forum where most owners congregate. I would suggest joining up if you haven't already as there is much to learn about our odd machines if you are interested in doing so.
With that said, if you had actually read this thread in its entirety, or if you had participated on the 4C board and read the parallel thread dedicated to our specific cars,
http://4c-forums.com/16-engine-technical/17537-any-oil-nuts-here.html, you would know that the 4C, which has the same engine worldwide, and apparently the same derivative engine as in another recent Alfa as was pointed out earlier in this instant thread, has the Chrysler spec that you cited only in the USA. In the rest of the world, it is a C3 oil spec as this thread has discussed, hence the discussion about C3 oils.
Edit: I will say though that, if the USA only spec that you cite which is satisfied by the Pennzoil oil that you posted which is also an A3 oil, this also answers our speculation in this thread that, for USA cars, perhaps due to our higher sulfur petrol content, an A3 specced oil is what we are after.
