Nice!
But where's the complexity?
Would it be simpler with a magpie's nest of vacuum hoses, wires, plastic lingages and 200 hour life indication bulbs?
Yes, it is much less error prone and much more exact.
No, you can't do backyard, semi-functional, repairs as you could with the old analog stuff just using a roll of tape and a paper clip.
Yes, you can do lots of repairs yourself with quite cheap digital tools with the help of internet and ,like, ebay.
Had a car where most of the "automatic" stuff ran on vacuum, designed much like a computer but never quite worked. Neither did the french vacuum controlled carb... Prefer digital, no fuss, controls any day.
Same with ECUs, on our old boat the GM 350 and the (beautiful) Edelbrock carb spat out like 230 hp, drank fuel and the carb had to be adjusted for everything all the time.
The newer 5.0 Gi, starts in 0.5 seconds, 250hp, 30% less fuel, idles like a clock, takes all kinds of gas. And, much fewer parts in that engine!!!
But, for those that likes mechanical, analog, visual controls the digital controls are intimidating but they shouldn't be.
