So my motor expired on an OCI where I first used an MOS2 additive about 2 years ago, as much as I want to try it again I'm a bit hesitant. The additive was Lubro Moly Mos2 anit-friction engine treatment.
It was my 02 Honda S2000, running Amsoil 5w30 and the recommended amount of MOS2. My motor puked the main bearings just driving down the road for no apparent reason. To this date we can't figure out what caused the event. It has to be lubrication related. It is rare for this motor to lose the main bearings, usually the rod bearings fail first but they seemed to be okay. The oil pan was full of bearing chunks. I replaced the block with a used one as the crank was scored, and the cylinders were scuffed. We replaced all of the bearings, seals, piston rings, and the oil pump with new Honda replacements.
Everything I've seen says that the additive won't block the oil filter, but I can't help but think that maybe it did on my car - I always use the recommended Honda PCX filter. Since I've stayed away from Moly additives I've been running Red Line oil to get my moly fix.
Is there any chance that a moly additive can cause lubrication issues ? I understand that it may have been a coincidence since we did not find the cause of the engine failure, I'd like to try the additive again but I've been in no hurry to do so up to this point in time. Thanks for any replies on this.
