I have most of my needs covered. I use Valvoline synpower for most of my grease. I also use Lubrimatic Marine for my boat and all trailers. What I need is a grease for offroad use like dirt bikes, snowmobiles, etc. on their chassis, bearings, etc. I am thinking a moly grease would be best, and as water resistant as possible is best. I am even considering the lubrimatic marine if anyone has tried that.
I was also wondering if anyone had a light grease for ice fishing, tip ups in particular. They make tip up grease, but its very expensive. I grease my tip ups and reels every year, and it probably takes a tube of grease. It turns out to be about $40 in the expensive ice reel and tip up grease. All it needs to do is be very water resistant and work in temps from -40 to 20 degrees. The best I've found is regular nlgi 2 wheel bearing grease thinned out with gun oil. Thanks.
