Originally Posted By: Rand
I dont want to beat a dead horse but I've never been particularly happy with M1 Grease tried 3 different tubes and it always separates and runs out of my grease guns.
Other Greases maybe a drop or 2 but not this waterfall with mobil 1.
I prefer Green Grease for my tractor(s) and trailers.
For a car I'd consider a few options. AAP and TSC have good selections.
Do you pull back the plunger on the grease gun after you were done using it? I started doing this and it makes a big, big difference. One time last year I forgot to pull it back, and sure enough, I found it a couple of weeks later starting to ooze red oil out of the gun. Been more careful to pull it back every time and thankfully nothing, it hasn't been leaking out. Which is good, I want to keep the oil in the grease.
I have been making it a point to pull back the plunger on the grease gun to keep as much oil in the grease as possible because I had a bad experience with using dry grease.
Back years ago, before I was relieving the pressure on the grease gun, I was using Amsoil Series 2000 Racing Grease. I used it for the U-joints, ball joints, and tie rods, etc.. Because I wasn't relieving the pressure, a lot of the grease oil dripped out of the gun. Had to wipe up a spot on the work bench. Didn't really think it was enough to effect the remaining grease in the gun. Then, our Dad repacked the wheel bearings on our SUV. We didn't notice anything amiss. After a while, I went to repack the bearings again. I wanted to clean the old grease completely with solvent, Dad was in a hurry and he repacked them without cleaning out the old grease. I'm glad I didn't wait too long. I discovered when we used the grease with the oil leaked out, it must not had enough oil to lube properly because the inner bearing on the driver's side was all black and blue, and had a hard time getting the bearing off the spindle. Had to replace the bearings. Funny thing was that there was only enough of the dried out grease to do that one bearing, we had to open a new tube to do the rest of them. And those other three bearings were great, no problems. Having the oil leak out so bad must had not left enough in the grease to lube everything properly, was left with mostly thickener.
Lesson learned, I started pulling back the plungers after that.
