On my 2000 Sierra, I have an issue with power lines and using the AM band. As in, if I'm anywhere near power lines... I might as well forget listening to any AM stations (garbage/static).
Is this when one would use an inline filter on the feed coming in from the antenna?
FM reception is perfectly fine, and the garbage/static is not coming from the engine/alternator/plug wires. The cause is power lines.
