Originally Posted By: Gito
Originally Posted By: The_Eric
Not really. Pretty easy either way.
Ok..then I will most likely put everything back together tomorrow and hold off on the valve head cover gaskets.
I did clean off some of the debris at the top of the valve cover so that when removed, very little debris is disturbed...
I blew compressed air into the intake opening and to my surprise debris blew out.
Probably debris that fell in when I was wrestling the intake manifold out.
I hope its OK to blow air inside these openings.
I'm being careful when cleaning around the area.
Any ideas or recommendations are greatly appreciated.
Last time I did one, I sprayed some Super Clean in there and let it sit, then hit it with the pressure washer. I repeated that process several times until the water coming out was clean. Hit it from all angles- stick the wand in the ports too.
