Originally Posted By: SR5
Just say we have three 40 weight oils from the same name brand manufacturer.
The first is a top shelf, full synthetic, 0W-40, MB229.5, BMW LL-01 etc
The second is a middle level, semi-synthetic, 10W-40, A3/B4
The third is a economical to purchase, mineral, 15W-40, SN
What would be the differences in VII's used (type and dose rate)?
Would there be a big difference in the quality of the VII's that is reflected in the purchase price of the product. Or is it more base stock and marketing ?
For me a full synthetic is about 250% more expensive than a name brand mineral.
0W40 & 10W40 - odds are something like this would use a Styrenic Polymer but the treat rates would vary depending on the base oil choice. For example the 10W40 could have as low as 6-8% and the 0W40 as high as 18%. These VII's are generally more shear stable (5 SSI) but require more product to get the same level of thickening (polymeric efficiency). These polymers get chosen typically for shear stability, deposit control and dispersency are the main issues. Remember VII is only one part of the entire formula - so the formulator has to balance the VII needs with the rest of the DI package involved.
The 15W40 would most likely contain an OCP. probably something in the 25-35 SSI range. These polymers typically have good efficiency (meaning you get the required thickening at smaller concentrations) but they don't have the same level of shear stability and some would say that higher concentrations contribute to deposits in certain engine tests. OCP's are generally the cheaper of the two, so the final price of the product may reflect that.
There are lots of reasons why a formulator or oil marketer would choose to use different VII/VM packages - sometimes it's a performance requirement, sometimes its for reduced manufacturing complexity, sometimes its price. When you think about all the little details that go on to get to that final formula just right - you can probably see why formulators get annoyed when internet gurus and aftermarket companies thinks it's ok to mix in their own "special ingredients" as a way to improve on the formula - especially when there is no standardized testing involved.
