So, the passanger door on my 2004 F150 won't open this morning. Didn't have any issues with it last night, up to about 11 when we all got home. I can lock and unlock the door with both the key fob and the physical key in the door. Won't open from the inside or outside. It is around 30 degrees so I sprayed down as much as I could on the lock and handle with deicer, but that hasn't helped either. Any suggestions? Family thinks someone messed with it (of course) Thanks!
